disable web https
disable web https
Description
Disables the secure socket layer (SSL) access to the switch on the default port (443).
Syntax Description
Default
Disabled.
Usage Guidelines
Use this command to disable SSL before changing the certificate or private key.
The following command disables SSL on the default port:
disable web https
This command was first available in the ExtremeXOS 11.2 and supported with the SSH module.
Platform Availability
